Eclipse amp blown or not?
  • 1
Only The Best
texas
So i have an old eclipse pa5542 4 channel amplifier and i was about to install it into my truck. i was testing out which speaker wire was connected to each speaker and while i was doing that it suddenly stopped working? the power light wont come on/ the power/ground/remote wire is all getting adequate powereven when i bypassed and put a wire striaght from the power to the remote it wouldnt turn on... none of the fuses are blown/ my ground on the battery and the ground on the amp is fine... i didnt see anything spark to cause a surge or anything but i will admit that i didnt have a fuse running through the battery cable to the amp so idk if its blown or what i might need to fix or replace or take apart??
plz help!
  • Locked
COMPLETED WTB Eclipse SC8365
I checked at Diyma and I signed up for an account but I cant post in the classifieds. Thanks for the tip, I'll keep a check there.
7
I have a couple 3000s and 5000s and cant remember the other two right off hand, but these will not work with your unit that I can think of by...
4
909
In order to answer your question, I would need to know what model (e.g. SW4200, SW7524DVC). Also, are you looking to make a ported box or sealed?
Only The Best
Only The Best
texas
Only The Best
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
