SOLD eD 16o.Kv, nine.2 & crunch 1100.2
  • 3
happe626
will take picture with new dates if needed
Product: (1qty) Elemental Design 16o.v2
Specs: (From eD datasheet)
Continuous Power Handling: 650 Watts
Overall Outside Diameter : 15.375”
Mounting Diameter : 13.750“
Mounting Depth: 8.125”
Magnet Diameter : 7.20”
Voice Coil Size : 2.5
Thiele Small Parameters @ x=0
FS - 23.00Hz
Qe - .42
Qm - 3.0
Qts - .36
Vas - 254 Ltr
Sd - 0.0872 m^2
Re - 7.0 ohm
Sd - 0.0872 m^2 effective radius
Bl - 22.10 T*m
XMag 21.00MM
XSUS 26.00MM
XMax 21.00MM
Sealed Enclosure Range: 1.5-2.2 ft³
Ported Enclosure Range: 2.2-2.5 ft³
Driver Displacement: 0.08 ft³
Purchased new old stock on Feb 2010 from another forum member. Used for 7 months powered by Crunch P1100 (below) & eD nine.2. Mech. Works 100%, As for Cosmetics 92-97%. Bottom sticker on motor has scratches. Pictures of scratched sticker below. Includes original shipping crate.
$150.00
Paypal / cash accepted.
No shipping. Local Pick up Only. no trades accepted.
http://img815.imageshack.us/img815/7088/dsc02126t.jpg
Even DC resistances.
http://img821.imageshack.us/img821/7731/dsc02135w.jpg
http://img542.imageshack.us/img542/7381/dsc02138x.jpg
scratches on sticker of magnet
http://img89.imageshack.us/img89/360/dsc02129b.jpg
Product: (1qty) Elemental Design nine.2
2x25AMP Fuse
100W x 2 @ 4 Ohm
200W x 2 @ 2 Ohm
400W x 1 @ 4 Ohm bridge.
Height : 2.250"
Width : 9.850"
Length : 12.000"
Overall Length(w/ feet) : 13.100"
Purchased used from another member with no warranty. Used for only 1 year. Mech. Works 100%, As for Cosmetics 92-96%. Small scuff on logo, overall almost like new.
$90.00 Paypal / cash accepted.
pick up prefer. buyer will pay shipping if necessary. no trades accepted.
http://img443.imageshack.us/img443/8116/dsc02058d.jpg
http://img84.imageshack.us/img84/8346/dsc02052x.jpg
http://img813.imageshack.us/img813/3769/dsc02051l.jpg
http://img715.imageshack.us/img715/3881/dsc02050a.jpg
http://img704.imageshack.us/img704/1102/dsc02049o.jpg
http://img708.imageshack.us/img708/2018/dsc02047ni.jpg
http://img836.imageshack.us/img836/9528/dsc02046f.jpg
http://img252.imageshack.us/img252/1884/dsc02045o.jpg
Product: (1qty) Crunch P1100.2 Powerzone Amplifier
Specs:
2x30AMP Fuse
PowerZone Series 2-Channel AB Car Amplifier
RMS Power Rating:
4 ohms: 112.5 watts x 2 chan.
2 ohms: 275 watts x 2 chan.
Bridged, 4 ohms: 550 watts x 1 chan.
Tuned Bass EQ (0-12 dB bass boost at 45 Hz)
Preamp RCA outputs
DC, short, thermal, overload protection circuitry
Variable high-pass filter (60-1200 Hz, 24 dB/octave)
Variable low-pass filter (40-150 Hz, 24 dB/octave)
Variable input level control: 0.2V-6.0V
Frequency response: 30-1200Hz
Dimensions: 13.38"L x10"W x 2.16"H
Purchased brand new about 7 months ago. It Was installed on a E39 with DSP. Mech. Works 100%, As for Cosmetics 87-95%. There is a small scratch on the brush silver bars. There is a picture below that shows the scratch. Was used to power 15" eD woofer & Alpine Type R.
Includes original box , High level input plugs, sticker and manual.
$65.00 local pick up
http://img714.imageshack.us/img714/3042/dsc02110dt.jpg
http://img593.imageshack.us/img593/2033/dsc02109.jpg
http://img34.imageshack.us/img34/1203/dsc02108o.jpg
http://img813.imageshack.us/img813/5931/dsc02107.jpg
http://img715.imageshack.us/img715/5029/dsc02106bf.jpg
http://img694.imageshack.us/img694/1062/dsc02105f.jpg
http://img262.imageshack.us/img262/8791/dsc02112m.jpg
http://img813.imageshack.us/img813/9263/dsc02119z.jpg
picture of scratch
http://img600.imageshack.us/img600/6059/dsc02114q.jpg
http://img836.imageshack.us/img836/6694/dsc02111r.jpg
Pictures of Crunch AMP installed on car. (pictures taken 2 weeks ago)
Pic1
Pic2
Pic3
Send a PM if interested. Either amplifier will power the subwoofer perfectly.
oops typo there.. i meant i can ship either amplifiers at buyers expense.
I won't ship the subwoofer because of the weight and size.
211
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
413
6
494
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
787
happe626
happe626
SGV soCaL
audio_phill
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
