Enabling Miracast for GPS nav apps
Lucky Phil
CarAudio.com Newbie
I was looking for a pinout wiring for a Hilux / Fortuna 2020/2021 head unit.
The reason being that the video is disabled when the car is moving. I wanted to miracast off road GPS navigation map apps.
My 2020 Hilux comes with a Denso Ten 86140-0kq10 factory head unit.
You can see the wiring plugs in the photos but there is no technical info on this unit.
:coffee:
:coffee:
Hi Phil,
Just got this from the the Toyota service page.
https://toyotamanuals.com.au
I just spent hours looking for the same information on the head unit, finding nothing. But then realised the cars wiring diagram would work. Took 10min once i singed up and paid the $16.50 fee to Toyota.
Hope this helps.
  • Denso Headunit.pdf
Thanks Chris,
Finally got back to try this.
Downloaded the wiring diagrams for the Hilux.
Only 2 signal wires need to be changed (for the Denso Ten 86140-0kq10 factory head unit): The park "switched to ground" (PKB disconnected and PKB head unit side grounded) and speed signal "switched off" (SPD disconnected).
Miracast is now enabled all the time.
Phil.
My friend maybe you can help us with some photos or informations. Only two cables needs to pinout pkb (purple) cable (to ground) and spd (pink) cable because at photo G203 mods you have lines to an other cables
This head unit has no power antenna adapter. So the image you are getting is not coming in from the correct program. Like if you were on an AM...
Hello everyone, This is my first post , I'm a total noob and was looking for some expert advice. I bought a 2010 Hyundai ix35 with a stock radio...
Lucky Phil
CarAudio.com Newbie
Lucky Phil
Australia
mike1959
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
