enclosure building- kerf math?
  • 4
jlund10
CarAudio.com Newbie
9
US
I've watched a couple videos and tried out 90 degree kerf bending, the actual cutting technique makes perfect sense to me.
I also understand that in order to get a 3 inch radius, I need 9 inches of total kerf length
what I don't get is how to factor the kerf bend into the length of material I need to cut.
If I were building a normal slot port enclosure, I would have my baffle length of 25.75" and my first port wall length of 9.5 inches.
Now if i want to make a kerf port to this same size does that mean I would simply add the length of 25.75+9.5" and kerf a 35.25" long piece?
Secondly where do i begin the kerf? would it be right where the baffle would normally end or before it.
Thanks for the help. there are a lot of youtube vids explaining how to cut a kerf( the easy part) but it seems no one wants to share the secret to the planning behind it.
I do mine the wrong way. I start the first part of assembly with the kerfed piece. I cut the piece longer than I need, glue it and screw it, then i table saw it off, or use my router. I never did figure out exact math on how to have it land exactly where I want.
so you’re saying you cut out the bottom piece and mount the kerf part to it first?
Tablesaws must make life so much easier
Yep. I’ve tried to do accurate measurements, but it changes depending on how much you round over the kerf corner. I can get it close enough that I can adjust the curve and make it fit, but it’s just easier to do the curve how I want and just cut it off.
And you need to start your kerf cuts before where you would normally end your baffle. You have to curve it into where your baffle would normally end at the port piece. It kinda depends on how sharp of a curve you want. You have to cut closer together to get a sharper curve. Ive done a few kerfs, but I’m no expert at it. The inside of my kerfs usually end up with some fiberglass fill, since I find it easier to take out more than I actually need, curve it how I want, and fill it with glass. It may be the amateur method, but it works.
You figure the circumference of your radius then divide by 4 for 90 degrees 8 for 45 degrees. That will give you the length of the kerf. Example: 2 inch radius is a 4 inch dia. circle. The circumference of a 4” circle is 12 9/16. Divided by 4 (90deg) is 3 1/8”.
Or you could just use the kerf calculator on the Ultimate Car Audio App.
Thanks. does this mean in order to cut my baffle and port to line up perfectly, I just need to use this equation and add it to the total length?
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
699
jlund10
CarAudio.com Newbie
jlund10
US
GTSQ
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
