Enclosure for car speakers
  • 2
Santo_101
CarAudio.com Newbie
Norway
I have now 2 sets of 6" and 2 sets of 6x9" which I've wanted to repurpose into it's own enclosure alongside 1 or 2 Kicker L7 12" subwoofer for both home usage as well as in the car, but I have no build experience and now can only imagen how a setup like that would look like. Any thought's and/or idea's or even done a project of this kind already?
I have now 2 sets of 6" and 2 sets of 6x9" which I've wanted to repurpose into it's own enclosure alongside 1 or 2 Kicker L7 12" subwoofer, but I have no build experience and now can only imagen how a setup like that would look like. Any thought's and/or idea's or even done a project of this kind already?
So you want to build a stunt wall? Just build the appropriate sized box for the sub and attach the speakers around the sub. Be sure the have those speakers on a separate amp from your interior speakers with an on off switch
If your intent is to line your rear deck with the speakers I personally advise against it but it's fairly simple to cut the deck and fab mounting surfaces for the speakers. The subs will exert force on those speaker unless they are in sealed enclosures. That said people have 6x9 in the rear deck all the time with subs. Modest sub stages don't cause damage but a large substage can damage the rear deck speakers
It's considered to build an enclosure for this in mainly stationwagons as that is what I mainly drive, and have 2 separate builds as I currently have two stationwagens available. So either double 6" and 6x9" or mix it up with one 6" and one 6x9" as well as the subwoofer
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
674
i didn’t get to hear it yet. He’s supposed to install it this weekend.
30
3K
Santo_101
CarAudio.com Newbie
Santo_101
Norway
Santo_101
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
