Enclosure ports
  • 2
No. If you use more than 1 port, divide the volume of the box by the number of ports then calculate using that number with the size (cross sectional area) of the port you intend on using. You can use different sizes of cross sectional area but the length will change.
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
711
i didn’t get to hear it yet. He’s supposed to install it this weekend.
30
3K
Nitro_AZ
Nitro_AZ
tucson, az
THATpurpleKUSH
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
