BCotrell
Is 1.5 cubic feet net per sub enough for two 10" american bass xfl? The enclosure is ported tuned to 35 or 38
do u like the hds3 better then the xfls?I run 10s alot..Have 4 cuft @32 htz on a pair of HDS310s..sonds great..Ran a pair of XFL 10s in same enclosure and did well also.You should be just fine in that enclosure..Just watch it on the lows..but will work just fine..Run it!!
I actually like the XFLs for all out SPL, and do great for the power handling..no doubt..but also like the HDS310s just as well as slamming and a bit more of SQL if you will..The XFLs seem to be a bit better built in my opinion,with being stitched as well as a heavier duty styled basket,and Ive never seemed to be able to discolor a coil on an XFL as I have with a HDS3, with same power and box for both..But both serve very well,and get down pretty nice when need bedo u like the hds3 better then the xfls?
No one can actually say for certain without trying both...Yet..It also is vehicle dependent more than anything..in my opinionI know the hds are more for sql so im wondering if the hdc3 since it has more xmax than the xfl if it will be louder with same box amp and everything.
Ill bet that the HDC3.0 will ...and get pretty nasty doing itI know the hds are more for sql so im wondering if the hdc3 since it has more xmax than the xfl if it will be louder with same box amp and everything.
