Entry level subwoofers
Jay408
View attachment 26545992View attachment 26545992Hi, I am new to this site. I wanted to find out what is the best bang for the buck entry level subwoofers. Looking for two 10" or two 12" subs for $250. I listen to Hip hop, EDM, and R&B. I am looking for subwoofers with the best bass for the price of $250. I have a 2002 Hyundai Santa Fe with stock speakers and deck. Would I need to buy a new stereo and speakers?
Bass Packages at Crutchfield.com
I was looking for cheap subs and found these(the top subs). I was wondering if they are any good and are they good for the music I listen to?
Honestly it will be a bit difficult to hook up an amp and get your subs to sound decent without installing a new deck. If I were in your situation, I would find a decent cheap deck, a wiring harness, and a dash kit, all of which should be under 80 bucks from somewhere like Sonicelectronix.com
if you have the preminum monsoon audio, it might be best to keep your stock speakers, otherwise you could run some aftermarket off the deck's built in amp
as for the best bang for your buck here are my reccomendation's
1 - 12"
either
Pioneer TS-W3002D2 (TSW3002D2) 12" Dual 2 ohm Champion PRO Sub
which is my favorite budget sub
or
SSA Shop - Sundown Audio E8 sub woofer
for a better quality sound
you could put both subs in this box
Ground Shaker GSP 1 12 (GSP112) 12" Single Ported Enclosure
if you have your heart set on 2 subs
2 of these should do the trick
HDS210
in this box
Ground Shaker GSP 2 10 Dual 10" Ported/Vented Subwoofer Enclosure
and to for the power to run anything that I just recommended
Hifonics ZRX1200.1D 1200W Max Class D Monoblock Zeus Series Amp
that amp should have you covered, you
Honestly it will be a bit difficult to hook up an amp and get your subs to sound decent without installing a new deck. If I were in your situation, I would find a decent cheap deck, a wiring harness, and a dash kit, all of which should be under 80 bucks from somewhere like Sonicelectronix.comif you have the preminum monsoon audio, it might be best to keep your stock speakers, otherwise you could run some aftermarket off the deck's built in amp
1 - 12"
either
or
HDS210
in this box
Nononononono, you got it all wrong dude. OP, do NOT get a prefab box whatever you do. Either get the soundqubed sub mentioned by macsdad or an XFL, they can be had for cheap used and are darn good woofers for the price. I would be willing to sell you an extra XFL I have and my amp, a Hifonics BFX1600.1D for $250+shipping.
I recommended prefab because not everyone has the aptitude to build an enclosure, or the money to have one shipped, granted that there is noone in your area who offers box building, but yes OP avoid prefabricated Subwoofer boxes if you can, you get a much better result out of custom made enclosures, but if you don't have a choice, the ones I recommended will do, but you will be missing out
and jrdn's deal sounds pretty sweet, that stuff will bang
There are vendors around building and shipping boxes for almost the same $ ... Fuckk prefabs
Factory. 2021 Chevy Silverado custom trailboss
9
853
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
5
877
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
738
I came across those too. Seen all the drivers out on the alibaba sight for sure. Wonder who is making them for PPI? Looked long and hard at those...
28
Jay408
Jay408
San Jose, CA
Timmy13091
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
