Estimated amp repair price
  • 2
nate1017
Got a Rockford Prime 500.1 that has been acting up on me, believe its got a short in the internal components where it will only power sub if pressure is applied to the mid left side of the amp pushing down on the top.....you guys got a clue how much it might be to fix this thing? Is it even worth getting fixed?
200
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
397
6
490
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
782
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
566
nate1017
nate1017
DeFuniak Springs Fl
GVP
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
