Expedition - Wiring new amp and subs to stock HU?
  • 3
pbMaxLax44
I am trying to wire up a new amp and subs to the stock HU in my 98 Eddie Bauer Expedition. There was a stock amp and sub but I have no idea how to wire up the new one.
Here is a link to the wires you see in my HU. It is the first one on the second page, that is amplified with the two seperate harnesses.
http://installdr.com/Harnesses/Ford-Wiring.pdf
I am guessing I need to splice the blue turn on wire for the amp to "I" correct? There is already a solid blue wire in that port that's about the same gauge. Since I'm not using the stock amp anymore do I just replace it with my new wire, or does it have other functions so I should splice it?
Other question, where the hell do I wire in the RCA cables coming from my amp, I know I'll have to get an RCA to speaker wire converter but where will the L and R go for those?
is the amp for the speakers or a sub?
the thread title is new amp and subs.
yes, tap the I wire in the harnes for the factory amp remote turn on (verify voltage with a DMM). this will be the remote turn on for the aftermarket amp.
A LOC will need to be used if your amp doesn't have high level inputs. PAC-Audio has some vehicle specific harnesses and OEM adapters for your vehicle:
Pac-Audio.com Product Search | iPod Integration for your car and More by Pac-Audio - Connecting you to the future
ideally, you'd steal the factory sub signal, or you can grab the speaker outputs to any full range drivers.
Can anyone in here participate in a short interview I am doing for school about the installation of a Kenwood DMX4070S in my 2005 Ford Expedition...
Many whom bypass the OEM amp, tap into the harnesses there. It is all there in one spot so no need to remove panels or runners. Just Google 2017...
The Regulator for my car is built into the harness, I keep forgetting that VAG cars are fucktarded sometimes.
5
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
186
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
7
587
pbMaxLax44
pbMaxLax44
Indiana
keep_hope_alive
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
