SOLD F/s Amp
Jordantyler
arkansas
a1000db power acoustik amp
500 watts x 1 into 4 ohms RMS, 1100 watts x 1 into 2 ohms RMS
4-way protection circuit, bridging synchronization
Variable low pass, subsonic filter and subwoofer EQ
Remote dashmount low level gain control with cable
Dual mono speaker output connectors
1 ohm stable
Gold plated heavy duty power and speaker terminals
Full regulated PWM power supply
130 shipped!!
nice avatar XXX who is that?
No the amp is Not Rated at 1ohm, but I am sure you could run it at 1ohm and be fine depending on your imp rise. If you wire it at 1ohm final your not going to be at 1ohm after imp rise. Probably will get hot after awhile as well, thats how my 3000dbs run at .7 did.
183
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
384
6
483
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
770
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
559
Jordantyler
Jordantyler
arkansas
icpurplepplalot
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
