Factory amp vs Kenwood headunit amp?
superquest
My son has a 97 Avalon with a factory amp that pushes the 4" component set up in the front and rear doors. I have no idea what the RMS is on the amp but have been told probably no more than 10-15 watts rms per channel. Wouldn't even a factory amp put out a cleaner sound than a aftermarket headunit? The headunit is on the way and is the Kenwood KDC-352U. It has front, rear, and sub pre amp outputs.
So my question is should I bypass the new Kenwood headunit and hook up the factory amp or bypass the factory amp and use the 22 watts rms that the Kenwood headunit provides?
here's what i did on my Bose factory amp, when i replaced my head unit, i changed my 4 door speakers and bought a little 4 channel amp to power the doors, i left the factory amp to run the tweeters on the car.
i also added a sub amp to run the sub.
Realistically, if measured by industry standards, Kenwood and most other head units provide about 15-18 watts RMS per channel, and that's if the voltage is at 14.4 (rarely possible with flimsy factory wiring to the battery as well to the head unit). Having said that, I wouldn't shed any tears over disconnecting a decade old factory amplifier. Of course, getting an aftermarket amplifier is much better.
Can I have some of the crack you're smoking? Seems like good stuff......
Please tell me what kind of factory amp (minus some of the newer Bose/Sony/etc systems that come stock in some cars) are worth half a shit. Every stock amp I've replaced has been blown out of the water by a HU's built in amp
from what I understand, most factory amps dating all the way back to the early 90's can do 20+ watts rms clean per channel. HU's typically are rated around 15wrms per channel but much higher distortion, around 1-3% THD. So many HU's can only really do 10-15wrms clean. That's weak as fuck.
from what I understand' date=' most factory amps dating all the way back to the early 90's can do 20+ watts rms clean per channel. HU's typically are rated around 15wrms per channel but much higher distortion, around 1-3% THD. So many HU's can only really do 10-15wrms clean. That's weak as fuck.
I guess it depends on the vehicle. Like I said, each time I've installed a HU it was a great improvement over the stock amp.
A factory amp without a step-up power supply will have the same power as a HU. You can only get so much from 12 volts.
The difference is that factory amps usually have crossovers to protect the speakers. That limits how much midbass you can get from the OEM front stage, and it's what drove me to replace mine with aftermarket. When I ran my system directly from the HU I got an overall improvement in SQ but the power level (volume) was the same.
In the 90s, the sound system would have to be "premium" to give you anything more than 5-10watts RMS, and then they often had bizzare sound enhancing features, like silent bass boosters, bass reducers, etc.
wife's '03 G35's factory amped bose system is extremely weak, it's not clear or loud. I pulled one of the tweets out of it the other day because I thought it wasn't working, it was but it looked like something out of a transistor radio. My '05 f250's factory system put it to shame.
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
Got it figured out. The PAC LP7-4 LOC seemed to do the trick, and brought the noise down to a very quiet hiss similar to the stock radio...
4
You can run the SVC subs on the GM-DX871 at 1 Ohm, just lower the gain at the amp. The third sub is too different to run on the same amp as the...
@1aespinoza I see, so this audio volume leveling is what I was experiencing tapping into the Bose sub wires. Well then, I'm off to check out the...
4
superquest
superquest
Pataskala,Ohio
Kingstroker
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
