Factory amp?
The way to make it work is to buy the correct interface. You can use GMOS-09 to retain the amplifier or GMRC-04 for the cheap way but you'll have to bypass the amplifier. Since your car uses a data bus you can't simply hook up your remote wire to the factory amplifier to make it come on. This is the reality of factory audio integration these days.
Ok. I may just wait until i get an amp and new speakers. Thanks for the help though.
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
Got it figured out. The PAC LP7-4 LOC seemed to do the trick, and brought the noise down to a very quiet hiss similar to the stock radio...
4
You can run the SVC subs on the GM-DX871 at 1 Ohm, just lower the gain at the amp. The third sub is too different to run on the same amp as the...
@1aespinoza I see, so this audio volume leveling is what I was experiencing tapping into the Bose sub wires. Well then, I'm off to check out the...
4
Isaac
Isaac
Iowa
Isaac
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
