Favorite carpet shampoo/cleaner...
i use shout for my carpets, and bissell for the upholstry
works very fast, and is very effective. spray on, wait 10 minutes, rub with cloth, wait 5 more minutes, vacum it off.
oxyclean, tide with color safe bleach. use the powder and squirt a little water, just enuff to get a foam going and most of the grit out, dont use too much you can always add more. then scurb that **** hard and vacuum it with a wet dry vac then pour water on it and do it again and again till no bubbles or foam is left and let dry in the sun for a good 4-5 hours windows down
Folex is pretty good.
Its not foam but it comes in a spray bottle. You dont need to vacuum, just spray and scrub if its a bad stain.
Or simple green with an air compressor....
packerfan
packerfan
Beaver Dam WI
Dozerboy
