Figuring out the Resistance
  • 3
CheapPyramidStuff
I have an amp that's bridgeable at 4 ohms. Can I hook up 4 subs to these 2 bridged channels and have them run at 4 ohms? Does it work like this: Run the + of the amp to the + of #1 sub, run the - of the #1 sub to the + of the #2 sub, run the - of the #2 sub to the - of the amp. Then do the same except substitute subs 3 and 4 for subs 1 and 2? If that's wrong please tell me, but I think that's 4 ohms. Thanks.
seriously doubt if you would make 4ohm stable on those subs..
+/- **** isnt real important if you have a two way connect, it ony wants a closed circuit (+ = feed, - = feedback)... if you got a speaker with two plain cables you can unplug them and replug any way possible and you still have the same sound...
back to the question... what kinda amp is it ? Gimme all the species //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Editted: Figure of speech would be taking a mono (example) 400.1 amp and plug 4 ten inch subs on it, construction wise it would be like + and - from amp both go to distribution block and from that block four cable pairs run to the sub... and yes.. this would work altho its always suprising what kinda sound you end up with...
If you ask me just take a mono amp (good brand, good power and good rating - rf/pg/jl) and put two ten or twelf inchers on them...
another PS: yes, pyramid suxx0rs... they evil !
it all depends on the ohm ratings of the subs in question. how many voice coils is each sub and what is each voice coils ohm ratings? and how many watts does this amp put out bridged into 4 ohms. remember each sub will share the amps output evenly.
I am out of the car audio world the more my ears age. However, I am very much still a hobbyist in the electrical field. With much of my current...
15
Wow, I just finished the install of the Kicker DSC front and rear door speakers. What a night and day difference to stock. I will be purchasing...
7
JL has done some odd coil impedance in the past and I think still do 3 ohm coils on their W7. Their slash series amps are rated to drive 1.5 ohm...
11
CheapPyramidStuff
CheapPyramidStuff
Kamloops BC Canada
imral3
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
