First build VW Routan minivan
  • 3
25hz tuning is a good area if you're trying to get great sound effects out of movies. I have found it can seem a bit anemic if you try to start playing music played at normal speed on actual instruments.
IF your maybe plan is to possibly upgrade subs down the road you may as well just bump that box up to 8 cube net right now and give yourself more flexibility of what you can just plug and play into it when upgrade time comes. I would suggest that even in a larger box you will likely run into thermal limits on those subs before mechanical limits particularly if you're tuning so low. Also see if you can't get in some more port area to avoid turbulence. Those low frequencies displace a lot of air and port velocity will become a problem for you.
Well, I've owned probably over 100 different drivers in the last 40 years and almost every single speaker in the NVX line-up over the last 8...
16
737
https://www.youtube.com/@therealmatty_s/videos
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
910
I got to message a DD woofer builder a decent bit my last stent of box designing; they would send me designs to do for or with individual...
5
791
Currently Audison amps 500.1 and 4.300 with kappa 90csx 6x9 component set. Pair of morel 6.5 rear and a single 10” alpine type R.
7
858
MinuteMan
CarAudio.com Newbie
MinuteMan
Massachusetts
hispls
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
