First Car Audio Build... I need some speaker advice
  • 2
Mr. Mavan01
CarAudio.com Newbie
US
Hi,
I have a 2010 Toyota Camry. I'm looking to replace the front and rear speakers. Up front is a factory componet set of 6x9s. The rear has coaxials.
I have already decided to go with DD Audio speakers because it's a local brand that I support. I'm trying to figure out what the best option would be for the price...
FYI, I plan some running the speakers off of my Sony XAV-1000 so no amp.
1. screw the front components and do 2 sets of three way 6x9 coaxials. http://ddaudio.com/products/car-speakers/e-class-component-sets/ex6x9/ (cheapest option considering ease of install)
2. 6.5 components on the front and 3 way coaxials in rear (factory is 6x9 so idk if this is a good idea) (2nd cheapest option) http://ddaudio.com/products/car-speakers/e-class-component-sets/ec6-5/
3. 6x9 set of componets up front and 3 way coaxials in rear ( most expensive option but it retains factory size and placement of speakers) http://ddaudio.com/products/car-speakers/d-class-components/dc6x9a/
Thanks for the help!
-Mr. Mavan01
If you are just running off the head unit with no amp, dont even bother swapping speakers. Without acoustical treatments, proper active crossovers, and a large reservoir of amplification, you wont really feel any kind of upgrade with the swap.
Well, I've owned probably over 100 different drivers in the last 40 years and almost every single speaker in the NVX line-up over the last 8...
16
784
if you can read a simplistic book you can follow the directions to put together just fine. Its not rocket science. If you have questions about the...
344
Does you car have the noise cancelling mics from the factory? Usually right above the drivers door. If so, snip the wire to one of the mics to...
13
540
Mr. Mavan01
CarAudio.com Newbie
Mr. Mavan01
US
Jeffdachef
Brendon Jenness
    May 8, 2024
Doxquzme
    May 8, 2024
