First gen s10 door pods
  • 2
Blazin_Jason
This was my first fiberglassing project. Learned a lot and I'm happy with the end result. Still haven't heard them as I haven't installed the amp yet. They are 6.5" phoenix gold zr comps that I have had sitting for a while now. Had to sand down the tweeter rings to make more room. I made the rings separate because I hadn't really decided if I was going to do doors or kicks. No pics of the fiberglass, but it's pretty thick after a few layers of mat. Then applied some kitty hair and then body filler. My DA sander was definitely my best friend for this job. Covered in tweed and then painted the panels.
Will be ran off a sundown 100.2. I might not install the amp for a bit though. I need to build a new box and install rear battery. We'll see if they can keep up to the 2 15" BL's off strapped 1500ds.
Ive seen so many amps done this way over the years. Especially ones that had the Molex plugs and a couple others
9
837
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
You may need to go to some shows and sound offs/meetings
12
I honestly think that stock locations work great for 90% of the people. With today's DSPs, you can move the listening position anywhere you wish...
960
Blazin_Jason
Blazin_Jason
Vancouver Isl, BC, Canada
pd8731
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
