Tayta_Mayne 10+ year member
This will be my first time building a ported box. If you use just one port for two subs what are the down sides? Also Moe, can I stick 2 subs in any of your boxes from your box plan thread?
there is no down side as far as sound goes, you just have to make sure the port area is great enogh to stay away from port noise. depending on the kind of sub and specs for a 12" sub, you want at least 2-4" diameter port.This will be my first time building a ported box. If you use just one port for two subs what are the down sides?
No you don't want at least a 2-4 inch diameter port. You want a port with the required surface area. That's it.
No down side using one port. Actualy makes it easy. And you can add two drivers to the box plans as long as the internal volume and port surface area are great enough for both.
