First time installation
  • 2
Callingindogs
I'll be doing my first install in the next month or so, doing part of my build this following week. In my rear deck I have two 6x9's that I want to wire 2ohm the speakers are 4ohms each svc, how can I wire them down to 2ohms? eventually i'll be wiring the 4 door speakers to 2ohms also, the door speakers are also 4ohm svc speakers. Any tips about installation would be much appreciated //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
Hi, I have a 2015 Mercedes W205 with the standard audio 20 system, which is terrible to be honest. In my W204 it was really good even though I...
Generally you can still use the High Level inputs on most any amplifier to get it installed off the HU speaker wiring. Its a bit old school way of...
10
Callingindogs
Callingindogs
Fort lauderdale, Fl
mylows10
maylar
    Jun 2, 2024
    Jun 1, 2024
