First timer help
Kalebgotu
I've done a few little projects in various rigs but I wanna spend some big bucks on my jeep. I mainly am here just to make sure this setup will come together nicely. What better place for reinsurance than here! Here's what I'm trying to do.. I currently have 2 12" 2400 skar audio subs from a different rig I sold ill put those in these cool but seemingly overpriced DSB boxes I found online the other day since the current box I have won't fit unless I remove the back seat. I have a 2000 watt skar amp to power those. Next, I'm going to change the speakers to this alpine speaker kit and ill-use this cool alpine kta 450 powerpack amp to power. I also will be changing the head unit. I've never done a vehicle with two amps so what are your thoughts? any tips or tricks? Anything else ill need (besides wiring kit)
[https://www.amazon.com/dp/B01MXF8N5I/?tag=caraudiocom-20
[https://www.amazon.com/dp/B07QB4LJD3/?tag=caraudiocom-20
[https://www.walmart.com/ip/Jeep-Wra...=alpine+jeep+speaker+upgrade,aps,138&sr=8-16)
[crid=2XO58MMMPBN68&keywords=alpine+jeep+speaker+upgrade&qid=1643505685&sprefix=alpine+jeep+speaker+upgrade%2Caps%2C138&sr=8-16](https://www.amazon.com/dp/B09JX153GK/?tag=caraudiocom-20)
Seens like you got all squared away. Are you particular to Skar Audio? I have used the brand but have had reliability issues as well as others. As for that overpriced box; since you are paying a pretty penny, I think it better to have one custom made for your subs and vehicle. That way, you get the best performance out of them. Also Google Big3 upgrade, big benefit.
Problem resolved - Found a scrap Astra that was fitted with that same unit. Salvaged the Display and original plugs and wired it up on the dining...
112
433
406
Kalebgotu
Kalebgotu
Aberdeen wa
    May 31, 2024
    May 24, 2024
