Fixing Brake line help!!!!!!!!!!!!!!!!!!!!!!!!:)
Just the one. a couple of wrenches is all you need. Make sure you bleed them when your done.
i am not sure what you mean. so i take off the tube, replace it with the same size line, then how it pressurised now? whats the next steps?
How to bleed your brakes: start at passenger rear wheel, have someone pump the brakes about five times and HOLD them. Then you open the bleeder valve on the caliper. then go to driver rear, then pass. front. then driver front. make sure you keep the master cylinder full. dont let the brake fluid get on anything you like. It stains and is a very good paint remover.
http://www.popularmechanics.com/automotive/how_to/4213448.html
schackel
schackel
San Francisco
hornedfrog1985
Decebal
    Jun 10, 2024
