fli audio
  • 3
Idk first hand but I've heard some of there amps are ok, and there subs are decent the vids I've seen maybe haven't been proper set ups but they seem ok. They don't have very much excursion, anything is better than nothing but it will probably not be King Kong in the trunk.
I can get Fli Underground and Fli Acid, which are similar entry level lines. So far my only experience with Fli Underground is a 2-channel amp I used to power tweeters. It's cheap but surprisingly good quality. I'm keeping it to re-use later bridged for a center channel setup. I couldn't justify spending more money when this FU360.2 amp will do just fine. My impression of the speakers and subwoofers is they're nothing special. It's a saturated market. I like the looks of the powered subwoofer enclosures, but like with many entry level brands the peak power ratings(which are meaningless) are splashed all over the product.
A Link would be very helpful. Id be interested in taking a look at some gear
215
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
339
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
ozzy87
ozzy87
mayfield, ky
trumpet
