Floating ground adapter not working in combination with KTP-445A mini amp [For the old timers!]
  • 2
Flyview
CarAudio.com Newbie
Hi everyone,
I'm hoping someone can shed some light on my situation (probably fairly obsolete these days)
Quick rundown of the parts:
Ford E250 camper
- has "common ground" speaker wiring. Only one ground is shared between all speaker positives.
Alpine UTE-BT73 head unit
- has "floating ground", aka modern +/- speaker wire outputs.
Scosche FGA floating ground adapter
- takes in 8 modern +/- speaker input (and a "ground" reference connected to headunit chassis) and outputs to the old school common ground system (4 speaker +, and one ground).
Alpine KTP-445A amp
-supposed to be plug and play with Alpine head units
-takes as input the entire harness from the head unit
-outputs the entire headunit harness as if it was coming straight out of the headunit, with a higher amplified signal on the "speaker-level" wires
Working setup without amp (1):
Headunit -> FGA -> car harness -> speakers
This is working great. Balance/fader works, all speakers are equally loud. If you disconnect the ground input for the FGA (connected to headunit chassis), then the audio gets a lot quieter.
Now, I am trying to add a KTP-445A mini amp to the setup.
Theoretical setup with amp in a modern vehicle:
Headunit -> KTP-445A -> car harness -> speakers
Non-working setup with amp and FGA (2):
Headunit -> KTP-445A -> FGA-> car harness -> speakers
This is not working properly. With the FGA still grounded to the headunit like it is in setup 1, there is almost no signal going to the FR and RL speakers. Most of the sound is going to FL and RR. If you disconnect the FGA's input ground, then there is seemingly equal audio signal going to all 4 speakers, but the fade and balance don't work properly (you can't isolate the audio signal to any one speaker). For example, if I set the the fader/balance all to FR, there is basically no sound at all. This also happens with the FGA input connected.
I have tried connecting the FGA's input ground to car ground, or to the amp chassis, instead of the headunit chassis, but the exact same thing happens. I suppose I could leave it as is with the FGA's input ground NOT connected since I don't really need fader/balance, but I'm afraid this could cause damage, or not be getting full power.
Side note: The Scosche FGA is very simple and only has some capacitors inside it. I initially had a different FGA: Peripheral FGA4. It had some extra parts in it (transformers?) and would actually produce heat! The Peripheral FGA worked just fine without the amp, but would not output sound at all with its input ground disconnected. With the amp, it would get quite hot with the input ground disconnected (and same non-working fader/balance), and with the input ground connected had the same problem with the sound going mainly to the FL and RR. I like the new Scosche one since it doesn't produce heat and waste energy. But I included this info as it could provide some clues.
I am trying to understand what's going on but it's difficult without understanding what a floating ground adapter does internally.
Can anyone shed some light on how a floating ground adapter works electrically and what it's supposed to do? Why isn't fader/balance working anymore? Why does sound go mainly to two channels when I connect the FGA's input ground like it's supposed to be? Where should I ground the FGA now that the amp is in the picture?
Can anyone shed some light on how a floating ground adapter works electrically and what it's supposed to do? Where should I ground the FGA now that the amp is in the picture? I have ordered a Scosche floating ground adapter to see if it's any different but I suspect it won't be.
Since you introduced the amp, the FGA should ground to the amp chassis. Out of curiosity, is it difficult to run ground wire from the amp to the speakers? I think it is best to update .
I tried that and the same thing happens as when it's grounded to the headunit: sound mostly goes to FL and RR.
Yea, running new wires would be great, but I've never done that before and getting to the rear of the van will definitely ****. I will probably eventually do this for the best quality anyway but I'm also just very curious what's going on here electrically. I want to understand how the FGA is supposed to work and why it's not working.
I updated the original post to simplify it a bit and re-frame it with the new Scosche floating ground adapter. This adapter *is* different, as it only has capacitors and does not produce heat like my old one. Unfortunately it manifested the same issues. Any insight is appreciated!
I have a 06 grand Marquis. Looking at either Kenwood or Sony Apple play. Is it worth have a floating monitor? Pros and cons?
I agree with the brightness thing. I have mine set to black out in 5 seconds, lol. Never noticed the crossover issue since my dsp handles...
4
I'm guessing that's what it is. There's not a lot of room back there.
12
It’s nice having a test bench. That one is nice and clean! I don’t have pics of mine but mine is built all out of wood with carpet top and all...
16
In the following order: DOWN4SOUND JFX653S - 6.5 INCH 3 WAY CAR AUDIO SPEAKERS - I did a good listening of these and was pretty impressed. It...
20
3K
Flyview
CarAudio.com Newbie
Flyview
Toronto/San Diego
Flyview
Brendon Jenness
    May 8, 2024
Doxquzme
    May 8, 2024
