SOLD For Sale
  • 3
RMF419
2 Peerless 830970 2" Full Range Woofer $30 plus shipping
Frequency response: 150-20,000 Hz *Fs: 147.5 Hz *SPL: 85 dB 2.83V/1m *Vas: 0.007 cu. ft. *Qms: 3.06 *Qes: 0.7 *Qts: 0.57 *Xmax: 1.8 mm *Dimensions: Overall diameter 2.17" (2.56" diagonally ear-to-ear), Cutout diameter 1.97", Depth 1.31
2 Tang Band 25-302SH 1" Shielded Neodymium Dome Tweeter $25 plus shipping
Specifications: *Power handling: 80 watts max *Voice coil diameter: 1" *Impedance: 8 ohms *Re: 6.0 ohms *Frequency range: 1,400-20,000 Hz *Fs: 1,400 Hz *SPL: 91 dB 1W/1m *Dimensions: Overall Diameter: 2-3/4" x 2-1/8", Cutout Diameter: 1-15/16", Mounting Depth: 1"
2 Audiopipe 3way passive crossover $20 plus shipping
Woofer 20hz-700hz Midrange 500hz-3.5khz Tweeter 4.5khz-20khz
2 BB-133 $5 plus shipping
Treble/bass blocker-133UF 50v non-polar 10% cap
Treble / Bass Blocker - 133UF 50v Non Polar 10% Cap (300hz @ 4 ohm)
2 Scosche Audio Y Cable $6 plus shipping, never opened.
1 P3 Battery Terminal Platinum – Tri oval $4 plus shipping
2 Kicker SSMB65 4ohm $20 plus shipping only 1 works. Dropped the other.
2 Pyramid Pro W64 $10 plus shipping only 1 works. Poked a hole in one.
Power handling: 100 watts RMS/200 watts max *VCdia: 1" *Impedance: 4 ohms *Frequency response: 65-3,600 Hz *Magnet structure weight: 30 oz. *Fs: 67 Hz *SPL: 96 dB 1W/1m *Vas: 0.02 cu. ft. *Qms: 3.72 *Qes: .93 *Qts: .74 *Mfg. #W64 *Two-year manufacturer's warranty *Dimensions: Overall Diameter: 6-1/2", Cutout Diameter: 5-3/4", Mounting Depth: 2-3/4".
2 Tang Band W69-1042J 6"x9" Subwoofer $50 plus shipping
Power Handling: 90 watts RMS/170 watts max *VCdia: 1-1/2" *Impedance: 8 ohms *Re: 6.5 ohms *Frequency range: 35-350 Hz *Fs: 35 Hz *SPL: 87 dB 2.83V/1m *Vas: 1.34 cu.ft. *Qms: 6.05 *Qes: 0.37 *Qts: 0.35 *Xmax 7 mm *Dimensions: A: 6-1/2" x 9-1/4", C: 4-3/16".
Thanks for browsing...
i know that don’t change nothing thought i would share just let me know k if u want to text or email about it i will send u my info
6
e heard decent things, I've not used it, but for noobs, good place to start with that new DSP setup...
COMPLETED Full system sale
Changed my mind, the jetta is staying as-is and I'm buying the new car anyway, close this *****! Matt
RMF419
RMF419
Toledo Ohio
ghostmechanic
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
