Ford Escape
  • 4
15897
I'm going to be getting a 2003 Ford Escape which (I think?) has 6x8 openings in the front and back. I have some 6x9 speakers and, if it's possible, I'd like to use them in the Escape. I've used the search feature and haven't found anything, so I'm wondering if I'm going to be able to fit the 6x9's in there somehow.
Thanks for the help
you can make anything work with a sawzall and duck tape //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
so I'd have to cut bigger holes? I was going to have best buy install it because I don't know too much about this and I have an employee discount there. I also have some 4x6 speakers lying around, would I be able to get those in there with a kit without paying too much?
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
897
Ahhh, I had it in my head that it was 1 ohm stable for some reason.
41
3K
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
7
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
5
174
Minnesota
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
