Ford Fiesta Notch 2008 stereo wiring?
  • 1
vaynehelsing
CA
Hi everyone, someone knows what is the code color for Ford Fiesta Notch 2008?
It's produced in Brazil, in the harness I got the following wires:
Black + Green
Green + Yellow
Orange + Black
Orange + Black
I understand this is for speakers:
White
White + Purple
White
White + Pink
Gray
Gray + White
Gray
Gray + Pink
Thanks in advance.
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
713
Ahhh, I had it in my head that it was 1 ohm stable for some reason.
41
3K
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
7
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
5
174
vaynehelsing
vaynehelsing
CA
vaynehelsing
SPLBassJunkie
    May 21, 2024
Mr FaceCaser
    May 20, 2024
