Ford Focus 2007 AUX In Adaptor
  • 2
mobbsy
Just a quick question about the aux in function on my 2007 ford focus, basically I'd like to connect an adaptor to the back of my cars visteon cd6000 head unit so i can have a 3.5mm audio jack that I can use to connect various things but i dont know what connector/adaptor to buy
I've attached a few photos so you can see what i'm rambling on about
Here is the wiring behind the headunit.
img197.imageshack.us/img197/3543/img0314pe.jpg
the reason im not convinced is because some of the adaptors available have headunits pictured that are slightly different to mine and the connectors look as if they won't fit.
looking forward to any help you can give and once again sorry if this has been posted to death as a lot of my searches led me to this forum!!
ta, Will //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
---------- Post added at 03:59 PM ---------- Previous post was at 03:58 PM ----------
img5.imageshack.us/img5/6466/img0317b.jpg
img231.imageshack.us/img231/2772/img0316rz.jpg
a couple of other photos to show what i mean
Wiring color code should be ISO, just like American radios. If you get your vehicle specific radio harness, it should have the same colors as that...
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
919
Ahhh, I had it in my head that it was 1 ohm stable for some reason.
41
3K
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
7
mobbsy
mobbsy
hereford, uk
beowolf150
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
