Ford Taurus 2005 SEL !!help!!
  • 4
chrisbloemker
So I have a Ford Taurus SEl (2005) with automatic climate control with the stock factory Head unit and stock front door speakers and Sony 5x7s in the rear. I was wondering if anybody can help me on how to wire a 15" Kicker comp sub http://www.sonicelectronix.com/item_8555_Kicker+C154+-07C154-.html to this system and run an amp (which I think should be a 5 channel) to the speakers or at leats just the rear ones. So I have a couple questions
-Which channel amp should I get?
-would these work
http://www.onlinecarstereo.com/CarAudio/p_18805_Hifonics_Txi_4408.aspx
http://www.cardiscountstereos.com/catalog%20page.asp?Product+%23=CX1800
-do I need this some advisor showed me?
http://www.crutchfield.com/p_142SLC4/Scosche-SLC4.html?search=lc4&ssi=0
I really just want the sub and the rear speakers to be wired up if at all possible wired to the factory radio.
if anybody could reply to this that knows what they are talking about please do so your help would greatly be appreciated.
factory speakers wont handle much of an amp if you want to stay cheap pick up some walmart vr3s there sharp and handle power, if you blow them there $20. get a 4 channel and a mono block amp.
can i have that hifonics 4 ch amp hooked up to (2) 5x7's (1) 6x8 and (1) 15" kicker comp? would that be possible?
that should work..i'd get a dual 4 sub so it can see 2ohm load off the amp and get a little more power....you'll have to use passive crossovers on the rear though...the amps internal active high pass will be fine for the front 5x7's
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
874
Ahhh, I had it in my head that it was 1 ohm stable for some reason.
41
3K
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
7
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
5
174
chrisbloemker
chrisbloemker
Orlando, Fl
hotshot27
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
