forward firing sealed trunk box.
  • 3
inferno1985
got a new car and the rear seats fold down, 60/40 split now the question is i want to have the subs firing forward and seal it off from the trunk. thing is i still have a little one that utilizes a car seat on the 60 split side. so when i dont have him in the car i fold down he 40 split side. now would it be worth building a box that fires forward and having the port on the 40 split side so that when i have it down it will fire into the car? most people i see that have forward facing enclosures have the port in the middle . im sure it wont really affect the sound. or will the port on the drivers side actually make it louder for the passenger? or vise versa. also. lets say i want to jam a little bit with both seats up. is that a problem that there will be just about 3-5 inches of space from the subs to the seats while both seats are up?
ill check it out. but i was kind of looking to get a custom box made. the subs i have i think require about 2.25 or so for each sub. so the box itself is probably going to take up the whole trunk if that.
doesn't matter if the port is on one side or the middle as far as how it sounds. and with a single slot port on the side, you maximize airspace (center ports take up more internal volume since you can't share a port wall with an enclosure wall).
I dont think this forum is letting that link work. It keeps changing it to a link to this forum. Try this. Just change the dot...
10
No problem. The Dayton ultimax is one of the better sounding sealed subs I’ve heard. I kinda want to try the 18 in my ride.
12
I scrolled thru there trying to find TS specs and must have missed them or they weren't displaying. Anyway, looks like 2cuft tuned to ~35hz was a...
9
And you (if you’re not a Ai BOT), for the sake of everyone in this forum, may want to quit posting, Your information is consistently off topic and...
48
7K
They have pre-cut wood if you pay extra at the hardware store. Just draw it out. But you'll have to pay extra. Then screw it in yourself...
7
inferno1985
inferno1985
keep_hope_alive
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
