found a box for my fullsize ext cab -- now what subs?
  • 2
crashprime
Ok, so I am going for a vehicle pre-fab box under the back seat of my 1994 Full Size Chevy Extended Cab.
All boxes for this application have similar specifications. The one I am looking at:
Mounting Depth 6.25
Airspace Per Sub (Cu. ft.) 0.9
I am open to ideas on what subs are going to perform well with only 6.25" of mounting depth and only .90 cu ft. per chamber.
I am not looking for super high end, as it is a '94 pickup for goodness sake. $50-100 per woofer, maybe $200-$400 for an amp is my budget range.
I was thinking HiFonics HFX12D4 12" x 2 and an AudioPipe AP-15001D (dual 4ohm voice coils, so it'd be 600w RMS with room for improvement later by wiring to lower impedence), but I was looking at the minimum sealed volume for that woofer and it's dang near twice what I have available at 1.25cu ... so that's kinda outta the question.
I'm stuck as to what sort of options are out there for me within my budget. Any help is appreciated!!
This head unit has no power antenna adapter. So the image you are getting is not coming in from the correct program. Like if you were on an AM...
Dammned good amps. I ran that series for years. I just sold my last GTQ400 last year. I still have a GTS600 left. that series will run up to 16v...
Start by laying the larger bottom panel in an open space, then slowly “dry” assemble it by laying the pieces where they go like a puzzle. It...
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
683
The it to a custom air brush guy and tell him what you want. You can always stain, plexiglass windows, and put led lights inside the box. Search...
6
728
crashprime
crashprime
United States
crashprime
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
