Found a Kicker deal
  • 6
That's a decent price for 2 new. Used it's pretty much on par. For $100, you'll be loud. Double that and you start getting into a completely different category, but for $100, you're going to do quite well. Get a decent 300w amp and build (or get built) a good box [makes the difference] and you'll be set.
Any respectable 300w amp you can get your hands on for a good price. Not a market I browse in, so I wouldn't be of service to you other than to tell you to find a Kicker 200.2, 300.2, 300.1 or 400.1(a bit much) at a good price. I'm sure there are hundreds of amps good in that power class, however.
This head unit has no power antenna adapter. So the image you are getting is not coming in from the correct program. Like if you were on an AM...
Dammned good amps. I ran that series for years. I just sold my last GTQ400 last year. I still have a GTS600 left. that series will run up to 16v...
It should do fine man. Id recommend this setup for the money.I have two of these amplifiers and they are great for the $coin. The Hawk 15s Slamm...
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
534
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
Reddish Neck
TD's & Beer
Reddish Neck
Racine, WI
Reddish Neck
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
