SOLD FS: 3k rms amp- 18" psi sub ( 3k rms) 25+ ft 1/0- rcas
BushJ311
NW, PA
Powerbass xa 3000d- was repaired and has worked perfect ever since. i have only ran it at 4 ohm. 2 ohm for a day or two.
18" sub. konaki motor. built by team psi. handles 3k rms. d2 coils. double leads. used for under 3 weeks.
around 18ft monster 1/0
7 ft knu flex
a bunch of smaller runs of kollusus
some welding cable with rings on end for big 3. will measure it all tomorrow
2 sets of stinger venom rcas 20 ft.
1000 or b/o for all of it. ( make offers on separate items)
Would rather split it up. will try to get prices for each separate tomorrow.
425 amp
350 sub
rcas 15 each
1/0 2-3 a ft
It won't power that sub anywhere near its full potential, but you can connect them.
10
Thank you guys! I will lower the gains with the multimeter as I have watched the youtube.
5
Set the voltage to 20 volts via DMM and it will equal out to around 100 watts. https://www.the12volt.com/ohm/ohms-law-calculators.asp#voltage
4
BushJ311
BushJ311
NW, PA
BushJ311
