FS: AMPS!!! Memphis, ARC, Audio Art, MTX
got-one-eight
Memphis 16-MCA3004 (75x4 @ 4ohm, 150x2 @ 4ohm)
Memphis 500D (500x1 @ 2ohm)
Audio Art 400.2 Brown (200x2@4ohm, 800x1 @4ohm)
Audio Art 400.2 White (Repaint)(200x2@4ohm, 800x1 @4ohm)
Audio Art 120.2 (60x2 @4ohm)
ARC Audio KS1000.1 (850x1 @ 4ohm, 1000x1 @ 2ohm or 1ohm)
Memphis 16-MCA3004 = MINTish.. only a few marks where the mounting screws actually touched the amp to moutn it. Basically when you mount it you won't see anything. I am the orginal owner.. purchased new at Bico Stereo.
Memphis 500D = I need to pull this amp out but it was perfect when it went in and I expect it to be near mint when I pull it out. I have seen these amps bench over 600w @ 2ohm.
Audio Art 400.2 Brown = 7/10 cosmetic.. 10/10 function.. great CLEAN SQ amp.
Audio Art 400.2 White (Repaint) = 8.5/10 cosmetic. I had to paint one side plate over the markings although they are easy to remember. Amp was originally brown but looks really good now. 10/10 function.
Audio Art 120.2 = This amp is basically mint except for the side plate I took to turn my 400.2 into a better looking white amp. So it has one black side plate. Still looks great and functions PERFECT
ARC KS1000.1 = Clean. 9/10 only a couple little scratches on one side. Does not come with bass control knob.
All prices are O.B.O.
Memphis 16-MCA3004 = $195.00 Shipped
Memphis 500D = $175 Shipped
Audio Art 400.2 Brown $175.00 shipped
Audio Art 400.2 White (Repaint) $200.00 shipped
Audio Art 120.2 $85 shipped
ARC Audio KS1000.1 = $295 shipped
POSSIBLE TRADES = ARC 4150XXK, ARC KS500.1, mid-high level components, Pioneer 80PRS.
Shipping on me!
I will get some more pics later..
384
526
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
got-one-eight
got-one-eight
Houston, Tx
onelivinlarge
