SOLD FS: Arc Audio XXK 4050 Like NEW!
  • 3
jmass03
FL
I bought this from my local shop with the intention of using it for my set up, however I have decided to go with a bigger four channel amp. It's in perfect condition.
The specs are:
Features:
Built-in variable 12db per octave crossover
Crossover range 55Hz-5.5Hz
Stereo/Bridged/Mono input model selector switch
Bass boost 0-18dB @ 45Hz
Short circuit, thermal, reverse voltage, over-voltage and DC offset protection
Very high damping factors
Optically isolated MOSFET power supply
Fully regulated power supplies produce full power output with battery voltages as low as 12 volts
Symmetrical, discrete power amplifier circuitry
Engineered to drive highly reactive loads
Built-in variable crossovers, 12dB per octave
12dB/24dB per octave subwoofer crossover
Remote bass boost 0-18dB @ 45Hz
Microprocessor controlled power supply and protection circuits
Designed, engineered and assembled in the USA
Specifications:
Power Output at 4 Ohms Stereo: 4x50 Watts
Power Output at 2 Ohms Stereo: 4x90 Watts
Power Output at 4 Ohms Bridged: 2x180 Watts
THD: Frequency Response: 20Hz-20KHz
Signal to Noise Ratio: 95dB
Signal Separation: >65dB
Transient Dist: Input Sensitivity: 250mV-2.5V
Bass Boost: +18dB @ 45Hz
Crossover (Butterworth): 55Hz-5.5Khz, 12dB Stereo
Max Current Draw: 46 Amps
Damping Factor: >300 @ 1KHz
Dimensions: 13"x8"x3.35"
I just want to make some of my money back. Bought it for $280. I'll get rid of it for $270 shipped. I've got plenty of references here and Ebay as well as several other forums. Just ask if you're interested. Thanks!!
  • Poll
Its not a huge upgrade and I'd argue you likely couldn't tell the difference.
  • Locked
COMPLETED Arc Audio Amps
Arc Audio Amps I am selling. KS300.2 - $200 OBO KS300.2 - $200 OBO KS300.4 (Not Pictured) - $250 OBO X2 2500.1 - $950 OBO Located in...
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
209
jmass03
jmass03
FL
Macklessdaddy
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
