FS Blown RF T5002 Power series amp
  • 6
grassroots
needs car audio rehab
1,250
ATL
RF T5002
Blown. It has to be something easy to fix... Just a few months after I bought it new it popped the 100A fuse in it. I put in the only other ANL fuse i had (300, big mistake) and it blew up my right door speaker when it turned back on. So it sounds like there's some sort of short circuit on the right speaker channel. Maybe just something conductive fell under or on top of the board?? Unfortunately, it's missing the center piece and it has a crack in the plastic (shown in pic) but it's not real scratched up, just a little dirty.
$50 shipped
free
75 watts RMS x 2 at 4 ohms
150 watts RMS x 2 at 2 ohms (250 watts RMS x 2 at 1 ohm)
300 watts RMS x 1 in bridged mode (at 4 ohms)
500 watts RMS x 1 in bridged mode (at 2 ohms)
1-ohm stable (2-ohm stable in bridged mode)
and it's safe to say these power series amps will put out 10% more power than rated.
edit: you know it's ready to throw down with 1/0 +and- connections.
75 watts RMS x 2 at 4 ohms150 watts RMS x 2 at 2 ohms (250 watts RMS x 2 at 1 ohm)
still got this?
on average these amps put out 35% more
What amp and Ohm load are you running? What are the dimensions of the enclosure? sealed or ported?Tuned too? You may be better off buying a pair...
975
  • Locked
I have a zapco 4.0 and 6.0 that was stored in an area near the beach and corroded it pretty bad. Never was powered since it was stored working...
14
4K
Everyone I found the problem it's the RCA cables, I had my electrician mate have a look and he pulled one of the cords halfway out and the subs...
14
grassroots
grassroots
ATL
2Dcore
