Fs) Digital Designs amps, 3 m3as and 2 m2as, **VIDEO VIDEO VIDEO!!!***
cdimic25
2 New M3a
1 Used M3a
2 New m2a
The M3a has been our most popular high powered amp for many years. The M3 was never designed for spec power, but was one of the first amps in this power range to utilize a high capacity quad power supply and rock solid output section. The M3a continues the tradition delivering over 3000 Watts of long term, SQ quality, RMS power at alternator charging levels. The M3a has been the go-to amp of choice for high performance sub systems.
Here are DD's Conservative specs...
Bridged NA
Channels 1
Cont Power at 1 Ohm 2200W x 1 @ 12v
Cont Power at 2 Ohm NA
Cont Power at 4 Ohm NA
Damping Factor NA
Dimensions (Inches) 21.5L x 9.13W x 2.5L
Dimensions (Metric) 546.1L x 232W x 63.5H
Dynamic Power 4000W x 1ch
Efficiency Thru Output 87%
Input Sensitivity 0.15V - 5V
Shipping Weight 21 lbs
S/N Ratio >100dB
Tested THD ≥1%
Tested Voltage 12v -14v
Variable Bass Boost 0-6dB @ 45Hz
Variable High Pass Filter NA
Variable Low Pass Filter 20Hz - 200Hz @ 24dB/Oct
$650 Shipped obo for New M3a
$575 Shipped obo for the used M3a (it has 0 marks on it its perfect!!!)
$450 Shipped for m2a
USPS, they need the money so i use them!
Item Pictures: http://www.youtube.com/watch?v=rjyMLvaJniw&list=UUoPctu88Gg9By-MS-7U-h4A&index=2&feature=plcp
All depends on voltage. Give them 15v and you'll see high 4s. I gave them 14 and saw every bit of mid 4k out of each. Expect 3k real power at 12v. Try and find that out of any other amp in its class!
I used to have a pair of dd audio redline 608s, for eight inch subs they were very impressive, at least until that ole upgrade bug bit anyway. I...
7
4K
I use K3b to rip cds and for converting to any file extension I use Sound Converter or Soundkonverter on a Linux machine but you should be able to...
15
633
That makes sense. I took it apart today. It doesn't look too impressive but it should be better than the head unit. I'm going to install something...
8
cdimic25
cdimic25
SPL KID
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
