SOLD FS/FT $500+shp 2K & Fi BL 15 D1
  • 2
blfuller123
DFW
Just as the title says amp and 15 $500+shipping. Both are in like new condition. The amp comes with the digital volt meter and the bass knob.
Sell just the amp for $500+shipping and give you the sub or sell just the sub for $500+shipping and get a free amp.
Also looking for trades: Watcha got?
The sub:
09 Dual 1, Flatwind, Cooling, Universal and Daily Options.
The amp:
Alphasonik PMA640HCA
4-Channel High Current Power Amplifier
RMS Power Rating:
160 watts x 4 chan. @ 4 ohms
290 watts x 4 chan. @ 2 ohms
490 watts x 4 chan. @ 1 ohm
500 watts x 2 chan. @ 4 ohms bridged
825 watts x 2 chan. @ 2 ohms bridged
960 watts x 2 chan. @ 1 ohm bridged
Hour Meter
Remote Mount Digital Voltmeter Included
Bass Remote Included
Heavy Duty Heat Sink
Beveled Clear Acrylic Protective Cover
1 Pair RCA Outputs
Tiffany-Style Input and Output RCA Jacks
High Speed Switching Power Supply
Double-Sided Glass Epoxy Circuit Board
Variable Low-Pass Filter: 50 - 250 Hz
Variable High-Pass Filter: 50 - 250 Hz
Variable Subsonic Filter: 15 - 60 Hz
Variable Bass Boost @ 45 Hz: 0 - 18 dB
Input Sensitivity: 200 mV - 8 V
Input Impedance: 10,000 ohms
4-Way Protection Circuitry: Thermal, Short-Circuit, Overload, and DC Offset
On-Board Hook Up Terminals
Frequency Response: 5 Hz - 50 kHz
Dimensions: 19-3/4" L x 9" W x 2-5/8" H
205
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
408
6
492
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
785
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
570
blfuller123
blfuller123
DFW
blfuller123
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
