FS/FT: Jvc KD-LH910 with KS-PD100 iPod adapter
WashYourWinky
The Pilot
10/10 mechanical 8/10 cosmetic normal wear for a head unit of its age.
Will come with the KS-PD100 iPod adapter, trim ring, wire harness, and install cage.
$90 shipped in the lower 48
I would trade for: mono amp, 10'' or 12" d2/s4 sub, oakley sunglasses. Make me a trade offer.
Will ship USPS
Specs:
SD Flash Memory Card Slot for playing MP3 Files
MP3/WMA CD/SD Recevier
3D Graphics Display
Detachable, Motorized Face
24-Bit Resolution(1-Bit DAC)
CD Changer (MP3) Control
RCA Outputs: 3 Pair (Front, Rear, Subwoofer)
Preamp Voltage: 4V
SIRIUS Radio Ready
MOSFET Power Amplifier:
Peak Power Output: 50 watts x 4 chan.
RMS Power Output: 20 watts x 4 chan.
i-EQ Equalizer: 8 Preset Curves + 3 User CHangable Curves
PiCT: Create your own background images
Google do it translate what ever i do
385
Hi, if no one here is able to help you figure it out, try over at diyaudio in the car audio section, it is a more technical forum. This is one of...
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
WashYourWinky
The Pilot
WashYourWinky
Cincinnati, Ohio
WashYourWinky
