SOLD FS: FUSION FJL-1611D 1600wrms CHEAP
Cmccloud
I have a used Fusion FJL-1611d. For some reason it works great on a 4 ohm load but once I wire it to a 1 ohm it won't work right and goes into protect. If someone wants a high power amp, high dollar amp(sells for $999) then this is the deal for you.
Fusion 1 Channel D-Class Linkable Amplifier CEA 2006 Rated FJL-1611D
Part #: FJL-1611D
Your Price Qty
$999.99
Detailed Description
1 Ohm / 2 Ohm Stable Linked
CEA 2006 Amplifier Power Standard Compliant
FUSION Regulated Amplifier Technology (F.R.A.T)
FUSION Intercooled Semi-conductor Technology (F.I.S.T)
FUTRANZ Efficient Heat Sink Transfer Technology
Gold Plated 4 gauge Power and Ground Connections
Gold Plated Audio Input and Output Connections
Gold Plated RCA Output for Multi-purpose installations
F-BASS Remote Controller Compatiable
Product Specifications
Bandwidth 10Hz - 50kHz
Signal to Noise >:95dB
Fuse Rating 4 x 30A
Separation >:60dB
Input Sensitivity 300mV-8V
LP Variable Crossover 40 Hz - 240Hz @ 24 dB / octave
HP Variable Crossover 40 Hz - 240Hz @ 24 dB / octave
Variable Bass Boost 0dB + - 18dB Gain @ 45 Hz
Variable Sub Sonic Filter 10 Hz - 55Hz @ 18dB / octave
Input Impedance 20K
Damping Factor >:200
T.H.D 0.06%
Dimensions D 65.5mm L 468mm H 276mm
CEA 2006 Compliant Amplifier Ratings
12.6 Volt Power Output Specifications
600 WRMS per Channel @ 4 Ohms and 1% THD+N
900 WRMS per Channel @ 2 Ohms and 1% THD+N
1250 WRMS Bridged Channels @ 4 Ohms and 1% THD+N
14.4 Volt Power Output Specifications
840 WRMS per Channel @ 4 Ohms and 1% THD+N
1250 WRMS per Channel @ 2 Ohms and 1% THD+N
1600 WRMS Bridged Channels @ 4 Ohms and 1% THD+N
Linked Power Ratings @ 14.4VDC
2850 Watts RMS Linked @ 4 Ohms
3400 Watts RMS Linked @ 2 Ohms
150 shipped
Ok someone wants this, $125 shipped to your door. Someone has to want a 1600wrms amp for 100. This weighs a good amount and is gonna cost more then 25 to ship so you will be getting it for less then 100. I jst don't need it, want to see it, anything.
I was thinking the cost verses the price of a new subwoofer wouldnt be worth the effort. Fusion Audio wasnt a very well made brand of audio in general
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
Well I finally had a chance to hook up the us acoustics amp. What a difference. Still playing around with the 13 band equilizer. The h/u put out...
Cmccloud
Cmccloud
LaFollette, TN
rusty_armadillo
    May 18, 2024
    May 18, 2024
