FS: HAT L3 set & BNIB Zapco (ESB) Reference 1.1" Tweets
  • 4
BlkonBlkFG
IL
HAT L3 set
SOLD
These speakers have been installed in my truck for appeoximately 9 months. They were bought and installed from an authorized dealer. They function perefectly. Cosmetically the only "problem" is that there is a little bit of sound deadening on the outside ring where the screws go from the install. These sell for $270 new.
•Overall diameter: 93mm (3.7-inch)
•Mounting depth: 46mm
•Bolt Circle Diameter: 85mm
•Mounting hole: 74mm
•Pnom (without crossover) 25W (AES Standard)
•Pmax (without crossover): 50W
•Pmax (with recommended crossover): 150W
•Frequency range: 129Hz - 10,000 Hz
•Sensitivity: 85dB (2.83V/1m)
•Mms: 2.274g
•Cms: 640 um/N
•BL: 2.961 T*m
•Voice coil diameter: 25.5mm (1-inch)
•Impedance: 4 Ohm
•DC Resistance: 3.4 Ohm
•Fs: 129Hz (free air)
•Qms: 3.468
•Qes: 0.717
•Qts: 0.594
•Xmax: 2.6mm (one way)
•Vas: 0.63L
•Sd: 2733mm2
BNIB Zapco (ESB) 1.1" Reference Tweeter Set
$200
These tweeters are brand new in the box. The only time they have been taken out is for pictures. All Zapco speakers are made by a company out of Italy called ESB. The exact model number of these speakers are KT6.25. These retail for $307. I have the spec sheet for these and will gladly email it to you upon request.
4-ohm
RMS power handling of 100watts
90 dB sensitivity
489
Time alignment is used to delay every speaker closer than the furthest to have the sound hit the listeners ears at exactly the right time. If this...
838
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
894
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
  • Locked
Send me all the items. Once I receive them, I will verify everything in your classifieds. If someone buys them, I will ship out. You would just...
BlkonBlkFG
BlkonBlkFG
IL
BlkonBlkFG
