FS: Hifonics 2500 Amp
Jd377
Hifonics HFi 2500
This is my Hifonics 2500, PERFECT CONDITION. 10/10 mech & 10/10 Cosmetic.
I just purchased 4 SA-10s and want to upgrade to a new Amp, so I need to sell this one first!!
I have the original box for it and the bass knob is unopened in the box. NO SCRATCHES at all.
$200 OBO --- Only trades would be for Sundown/AQ/Crescendo amps that are 2kw+ ( I would add cash for amps!!) or possibly batteries.
Negotiable
Edit: Added pics with username, I went and hooked it up for the pics to show that it works flawlessly and shows it powered on!
HFi Series Single Channel Class D Car Amplifier
RMS Power Rating:
4 ohms: 850 watts x 1 chan.
2 ohms: 1700 watts x 1 chan.
1 ohms: 2500 watts x 1 chan.
I do not have any gut shots, EDIT: I added pics with my name and date up there, hooked it up so you all could see it powered on! It works like it did when I first opened it!
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
12
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
I have a Gemeni VII, Heucules VII, Pluto VII, and a Vulcan VII left out of a massive slew of VII and VIII series. They still work Excellent...
5
3K
  • Locked
COMPLETED Hifonics Plato III
Yes, they are painted. The cover is very easy to take off and repaint to whatever color of choice to match the install.
So flat can be synonymous with bright? I assumed otherwise…shows my level of understanding. Speaking of mixing or mastering, the way it’s setup...
42
4K
Jd377
Jd377
Kansas City, MO
treadburner
Decebal
    Jun 10, 2024
