SOLD FS: JL 300/2 and Clarion 755VD w/ sirius tuner and ipod cable
  • 4
Blazin Civic
I got more bass than you
123
Earth
Amp is in mint condition and I still have the original box and foam. Only minor flaw is the screw is stuck in one channel but I have no problem with this since the other 3 clamp fine and totally lock the wire in. If you are bridging it this is of no concern since the terminal is not used. $180 shipped to your door. Please PM for more info or if you're interested.
Headunit is also mint and was in my car which is a weekend car and hardly driven. It is an awesome unit with a 7 inch touchscreen LCD. I have the sirius tuner box, data cable and antenna for it. The ipod cable allows you to hook your ipod to the HU and conrol it off the screen! This is amazing if you have a lot of MP3s. It pretty much makes CDs useless. For more info on this HU go to http://www.crutchfield.com/S-laT4BEIOHjT/cgi-bin/prodview.asp?i=020VRX755 . Asking $750 shipped which includes the the sirius tuner and ipod cable which are worth $150 alone.
is the screw stripped or just stuck? Might as well advertise it as a 300/1 class AB subwoofer amp:)
Good luck, its a great amp. I just sold 2 of them myself for more than you are asking.
free bump
free bump
Na I used it to run my front stage...it's stuck but it doesn't matter you can still put the wire in there fine and when you have the other 3 in it wont go anywhere. Worked for a year no problem.
164
This Is a NIB amplifier, one of two that I was to use. Decided to go class A/B on the front mids and tweets and just purchased a Helix B FOUR...
Good thing its under warranty and that you have contacted A.Control about the issue so it has been documented. It will help speed up the return...
Looks similar to this: https://www.sonicelectronix.com/item-17681-Clarion-CX609.html I'd call Sonic Electronics and see if they have what you...
Thats its manual fore using, not Tecnical.expaining , have pinted out service manual., and the cable i think was fore swc,its made fore satelite...
Blazin Civic
Blazin Civic
Earth
Blazin Civic
    Jun 1, 2024
    May 31, 2024
