FS: Kicker 2010 dx100.2 bnib **Pics**
  • 3
Zeuslicious
<< 28hz feels good
5,226
SD CA
1. Product:
KICKER 2010 DX100.2 BNIB
2. Specs:
RMS Wattage at 2 Ohm x 2 Channels: 50
RMS Wattage at 4 Ohm Bridged x 1 Channel: 100
RMS Wattage at 4 Ohm x 2 Channels: 25
Stable down to: 2 Ohms
Active Crossover: 18 db/Octave High Pass Fixed @ 100Hz, 18 db/Octave Low Pass Fixed @ 80Hz
Bass Remote Included: No
Bass Remote Capable: No
Channels: 2 Channel
Cooling Type: Heatsink
Frequency Response: 20 Hz - 20 kHz
Input Sensitivity: Low Level: 125mV-5V, High Level 250mV-10V
Recommended Amp Kit: 8 Gauge
Signal-to-Noise Ratio: &gt;95 dB, a-weighted, re: rated power
Dimensions (in): Height 2-1/8" x Width 8-5/16" x Length 8-3/8"
CEA-2006 Compliant: Yes
3. Description/Condition:
BNIB
4. Price:
$59.99 Shipped No trades!
5. Pictures:
Friday Again! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
818
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
Zeuslicious
<< 28hz feels good
Zeuslicious
SD CA
Zeuslicious
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
