FS: Kicker x3i 3-way active crossover
  • 3
FLboy4x4
KICKER x3i is a 3-way 18dB/octave active electronic crossover with one variable low pass and two variable high pass filters. Remote control bass boost is variable to +18dB at 40Hz. Also features 24dB/octave subsonic filter, two stereo inputs, and three stereo outputs for versatile control.
Features:
•Front and Rear High Pass Crossovers - 18dB/octave, Variable Frequency (35-400Hz; 20x Multiplier Option on Front Crossover)
•Sub Low Pass Crossover - 18dB/octave, Variable Frequency (45-250Hz)
•Bass Boost Variable to +18dB at 40Hz
•Remote Level Controller
•24dB/octave Subsonic Filter
•Two Stereo Inputs with Parallel Input Option
•Three Stereo Outputs (5V rms)
•Signal-to-Noise Ratio - >100dB
$60.00 shipped
Shipping included in price
View attachment 26525279View attachment 26525280
if it was one ten foot length then I would probally do it but if not sorry. And I dont really have a need for that eq of 5 gauge sorry
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
706
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
FLboy4x4
FLboy4x4
Lehigh Acres, FL
FLboy4x4
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
