FS: Like New Audiocontrol EQS <============================
  • 1
VerTigo456
For those that know anything about car audio...this unit speaks for itself! Do you have a head unit that is only putting out 2 volts and want to get the most quality out of your system? This is the unit for you!
Great sound for six channels, all in one unit. Separate inputs and equalization for front, rear, and subwoofer speakers. The EQS has seven bands of full and half octave equalization control for the front and rear plus six, one-third octave equalization bands for maximum bass control. Add to that the Programmable Frequency Match (PFM) filter and a low output impedance line driver and you get maximum output and sonic clarity everywhere in the car. And to easily use a factory head unit, the EQS has built-in speaker level inputs. Truly a product for those who consider perfection possible.
Manual:
http://www.sound-better.net/Support/Manuals/Autosound/EQS%20Owners_Manual.pdf
Key Features
Six Channel Operation Works With Newer Head units
Dual-bandwidth Equalization
Auto-mode Configuration Simplifies Installation
Programmable Frequency Match (PFM) Subsonic Filter
Line and Speaker Level Inputs
Balanced Inputs For Superior Noise Rejection
Input and Output Level Matching Controls
Retails for $289 new. Wanting $200 or open to potential trades
Fully test it without the ACR-1. TBH it sounds like an amplifier issue. Try connecting your phone direct to the amp via a 3.5mm to RCA cable. If...
709
Good thing its under warranty and that you have contacted A.Control about the issue so it has been documented. It will help speed up the return...
6
Looks like half a dozen other makes/models on the market, rebranded . The shallow mounts look like they’re made by Pioneer but what the hay, one...
8
Go to DIYMA some people there are willing to remote tune it for you for a small fee. Usually around 30-50 dollars.
VerTigo456
VerTigo456
Fort Worth, TX
VerTigo456
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
