Fs: Memphis mcd4kw almost mint condition $550 shipped
ACT Audio
ACT AUDIO
Item(s) for Sale: MEMPHIS MCD4KW
Item(s) Description/Condition: MOJO Series Monoblock Class D 4000W Max Amplifer
RMS Power Rating:
4 ohms: 1000 watts x 1 chan.
2 ohms: 2000 watts x 1 chan.
1 ohm: 4000 watts x 1 chan.
Max power output: 4000 watts x 1 chan.
Total Harmonic Distortion:
4 ohms: 0.5%
2 ohms: 0.75%
1 ohm: 1.0%
MOSFET power supply
Remote bass level input (remote level control sold separately)
Power, protection and blown fuse LED indicators
Custom black pearl finish
Signal To Noise Ratio: 95 dB
Input Sensitivity: 250mV - 9V
Input Impedance: 22Kohm
Damping Factor: >50
Output Impedance: 1-4Ohm
Low heat generation
Gold-plated RCA inputs
Buffered RCA low level output (loop through)
Variable low-pass filter (50-250 Hz, 18 dB/octave)
Variable high pass subsonic filter (20-50 18dB/octave)
CEA-2006 compliant amplifier
Dimensions: 31-1/2"L x 7-5/8"W x 2-1/2"H
Price: $550
We have used it @ 0.5 but only during burbs. Requires multiple batteries to maintain the 250-350a of draw..... Very reliable amp
  • Locked
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
https://caraudiobargain.com/audio-apex-cab-22-car-amplifier-monoblock-2200-watts-rms/ Since these are back in stock they're really hard to beat...
And the most important thing you've learned in life up to this point is to get offended on behalf of other people on the internet in the attempt...
18
5K
So recently I bought a Memphis prx1000.1 and installed it to 2 rockfordfosgate r1s'. Both svc and 150rms 4ohm. I wired them to a 2ohm load to the...
ACT Audio
ACT AUDIO
ACT Audio
Vernon, CT
ACT Audio
    May 31, 2024
    May 24, 2024
