QuadFather 10+ year member
DD Digital Design S4a
Item is new, has been in stored in my closet for 2 years.
Perfect for running an active setup.
SPECIFICATIONS:
Series S
Input Sensitivity 0.2V - 8V
Variable High Pass Filter 20 Hz - 500 Hz (200 - 5 kHz) at 24dB/Oct
Variable Low Pass Filter 50 Hz - 500 Hz (500 - 5 kHz) at 24dB/Oct
Clipping Display LED
Tested Voltage 14.4
Tested THD 1%
Model S4a
Cont Power at 4 ohm 100W x 2ch + 200W x 2ch
Cont Power at 2 ohm 150W x 2ch + 300W x 2ch
Damping Factor >550 @ 2 ohm
Cont Power at 1 ohm
Cont Power at 4 ohm Mono
300W x 1ch + 600W x 1ch
Dynamic Power 400W x 1ch + 800W x 1ch
Efficiency thru Output >64%
Dimensions - mm 420L x 232W x 63.5H
Dimensions - inches 16.54L x 9.13W x 2.5H
Signal to Noise 95 dB
$350 plus shipping
I will ship UPS or USPS at buyers discretion
SPECIFICATIONS:
Series S
Tested Voltage 14.4
Tested THD 1%
Model S4a
Cont Power at 1 ohm
$350 plus shipping
