SOLD FS: SI Mag15, DLS A5 (LOCAL ONLY- OC,CA)
  • 7
JAZN
SoCAL
I'm going broke so sadly I need to sell off parts of my system. For now, I'm only selling LOCALLY in ORANGE COUNTY, CALIFORNIA.
Stereo Integrity Magnum D2 15" $275
Cone/surround are practically flawless, the bottom plate has a small discoloration on it that came that way. Mechanically 10/10
http://www.stereointegrity.com/Magnum12.html
DLS A5 $350
A couple minor nicks near a few of the mounting holes, barely noticeable.
Most of the small specks in the pix are dust particles, I didn't realize the dust would show up so much :p
I did open up the amp to make sure it's not a fake.
Includes bass remote but I don't have the cable for it. It's uses a simple phoneline though, so you shouldn't have a problem buying one.
Number of channels 3
Amplifier class AB
Damping factor > 200
Mono bridge mode 4 ohm N/A
S/N ratio, A-weighted >100 dB
Typical power in 4 ohm 2 x 85 W
Typical power in 2 ohm 2 x 100 W
Mono sub channel 4 ohm 300 W
Mono sub channel 2 ohm 500 W
Input impedance, high level N/A
Mono sub channel output in 1 ohm 780 W
http://www.dls.se/en/car/prod.html?produkt=en_10
Amp sold. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
Is that a car show? Wow. Too much ground loops. The magnetic field may interfere with frequencies going to the antenna. Or you just need a...
15
JAZN
JAZN
SoCAL
JAZN
