FS: Sundown Audio SAX-100.4 v1
OmegaBunny
Moderator
Used Sundown Audio SAX-100.4 v1
Used to power a set of HAT L6 mids and SEAS Tweets (both will be available shortly). Condition is 9-9.5/10. A few small scratches on the heat sinks and one on the bottom along with the the usual marks on the mounting holes. I tried to get picture of everything.
The amp was ran gently, never clipped, never under powered.
4/3/2 Channel Bridgeable Class-AB Amplifier
MOSFET PWM Power Supply
Stable Into 4 Ohms Bridged or 2 Ohms Stereo Load
Variable Subsonic Filter
Independent 1/2 and 3/4 Channel High Pass Filter Variable
with x 10 Range Selectable Switch
Independent 1/2 and 3/4 Channel Low Pass Filter Variable
HPF/FULL/LPF Selectable Switch
Independent 1/2 and 3/4 Channel Electronic Crossover Slope Selectable
Switch with 12dB and 24dB Octave
Variable Input Level Control
Input Sensitivity : 200mV ~ 6V
Subsonic Filter : 10Hz ~ 500Hz
Signal Input and Line Out RCA Connectors
Multi-Way Protection circuitry (Thermal/Over Current/Speaker Short/Speaker DC protection)
Tested Voltage & THD: 14.4V & Less than 0.05% THD
Operating Voltage : DC10V~16V Power Input
$250 shipped. No trades!!!
Included
Sticker was from another amp. it has been removed.
image_zps0b6fe311.jpg.html
---------- Post added at 10:17 PM ---------- Previous post was at 10:17 PM ----------
Guts
Guts
Is American Bass better then Mmatts? Again I'm in love with quality and smoothness with alot of power and so far I'm Does the ABs have better...
12
Some of the NVX stuff seems alright, but the amps, especially the higher end ones, they seem suspect and sometimes show stats that straight up say...
13
5K
OmegaBunny
Moderator
OmegaBunny
Keyser, West Virginia, United States
BAPEKC
